i'm still trying to figure out whether to enable or disable it.
I've done some reading and checked a review from A and Tech
I did some test on my own and these are the results
LLC [Enabled]
Vcore in bios set to 1.30000V
Idle = 1.280V
Load = 1.280V
LLC [Disabled]
Idle = 1.272V
Load = 1.240V
LLC [Auto]
Idle = 1.280V
Load = 1.280V
When it is disabled i get those really fluctuating readings , and to be honest i dont think i would like my Vcore to drop that much when it is under load, talk about getting closer to unstability. I havnt even begun to
start tinkering with lowering my Vcore below 1.3000V yet. If it was Disabled it would probably go so low it would cause the computer to become unstable. Having it enabled keeps me at a constant 1.280V idle or load, i saw no spiking going above the 1.3000V that i have the Vcore set to in bios.
I used Prime95 Small FFT and CPUZ to get the readings fyi
A response i got on another OC forum was this
I"m just concerned that if i do leave it Disabled then when i start to lower my Vcore to fine tune my overclock, that it will cause it to dip too low and become unstable.
LLC [Enabled]
Idle = 1.280V
Load = 1.280V
LLC [Disabled]
Idle = 1.272V
Load = 1.240V
LLC [Auto]
Idle = 1.280V
Load = 1.280V
Yes I'm saying it's in the best interest of your components to leave it disabled. the charts on the anandtech article are talking about voltage changes that CPU-Z isn't able to detect since they happen thousands of times per second.
You don't have to worry about a vcore that is too low, it won't kill your components, but when you turn on LLC (or put on auto) it periodically spikes your vcore above what you set it decreasing the amount of control you have.
if your CPU is getting unstable under load, just raise the vcore in the bios to stabilize it. don't worry about the system becoming unstable, that's what the prime testing is for. As for max voltages, the e8*00 series can take up to 1.4v 24/7 easy as long as temps are managed.
