Load temps don't increase much?
20 Oct 2004
Is it indicative of a problem if the load temps being read by Coretemp aren't that different to the idle temps?
Previously, as mentioned in another thread, my core temps at idle were over 60C but I reseated the HSF (Scythe Ninja, wasn't on properly), changed the fan orientation and used AS5. Idle temps are now around 39C in a fairly warm room. Under Orthos load or after playing CSS for an hour or so the temps only rise to about 47C on both cores.
Is this normal, shouldn't it be a greater increase?
Motherboard is an Asus P5N-E SLI.
My E6300 and DS3 with a Tuniq Tower 120, react the same. About 35ish on idle and running Orthos peaks at about 45-50ish.
I wouldn't suspect there is anything wrong though, could just be a cooler running chip even.
