Loading temp
Suspended
17 Mar 2006
What's a good safe temp under load? I'm running Super pi 35 million, Bar on th the left is around 62% and CPU temp is 40-41 'c. MB is 27'c. Dual core system. How can I get Superpi to use 100% of both cores? System will be slow but want to check. CPU is 4400+ overclocked to 2.4ghz with RAM clocked to 242mhz. Idle is 35 CPU/27 MB.
You can try setting the Priority of the Super PI task to realtime
It's not a great test of stabilty though - use Prime 95 and/or OCCT for that
Temps are fine
