loading up for a stability test
Permabanned
18 Apr 2006
14 miles from OcUK
is it safe to run prime 95 toture test and orthos sp2004 at the same time?
im doin this now and it says cpu 100% in windows task manager
and core temp is reading 57-60 c
can i continue or might i blow her up :confused:
sounds like a rocket on take off at the mo :D
stinka
You can't kill a cpu running stress tests, however the extra heat induced by a stress test could kill it.
And in theory if its at 100% utilisation running any more stress tests won't make a difference to anything, it will just fill up the memory, the cpu will remain max'd out.
