Locating Adobe 9 Serial on already installed copy
26 Jan 2007
Surrey
Basically I have a copy of adobe acrobat 9 installed on my pc and im wanting to find the serial number that is currently registered to the copy im running.
Ive downloaded a few key-finding programs but they only show me the serial for the copy of windows im running and office etc.
I've heard it can be located in the registry but im unsure of the location of the reg file.
Thanks in advance
Adam18290
Problem solved: For anyone else having this same issue, the serial can be found in the registry, specifically hkey_local_machine\software\adobe\(current version you have installed)\registration and there should be a file called serial with a value (the serial) on the right hand side.
