- 25 Feb 2004
hi guys
my problem is that i set the graphic options to what i want it in the options to get the game to run at a acceptable frame rate and this works in every flight bar when i try to fly any of the campaigns as it seems to ignore my settings completely, it always sets the scenes to high which is killing my frame rate and sets civ traffic to none and i cant change either of these as no drop down menu appears but it does on the rest. i have tried setting the default , low, settings buttons and changing the rest to what i want but it just resets it back to settings it put in before. i have saved it with no difference and i even removed 2 first mission.sav files assuming it was my first mission to reset the campaign but it doesnt reset it as my progress is still there. any ideas cause i cant play the campaigns at a acceptable frame rate for me. all my drivers are up to date and the game is patched to 1.12a.
thanks
thanks
