Lock pc via GPO
Ish
Ish
11 Jan 2006
West Midlands
Hi
Is is possible for a pc to auto lock after 5 mins of being idle using GPO using SBS2011.
Yes you can, use GPO to enabled the screen saver to come on and password protect...
Administrative Templates\Control Panel\Display...
Hide Screen Saver tab = Enabled
Password protect the screen saver = Enabled
Screen saver = Enabled
Screen Saver executable name = %windir%\system32\logon.scr
Screen saver timeout = 300
After 5 minutes, the screen saver will run and the logged on user will be asked for their password to unlock the machine..
This thread reminds me of the old trick where you inserted a CD with an autorun command to kill the screensaver, thus bypassing the password :p
