lock pc
29 Jun 2004
what is the best folder to keep an intruder out?I mean say if my computer got stolen is there a program that I could use that locks my pc?thanks for any help
You can get programs to password protct you harddrive on bootup to prevent unauthorised access. This will encrypt the HDD if too many authorised attempts are taken to gain entry.
I can't remeber what it's called; Google and find out.
Burnsy
If you wanted to render the pc useless you'd need something integrated into the mobo. Otherwise they could just reformat the hdd.
