LOCK UP YOUR DAUGHTERS... LOOK WHATS OUT!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
This case is limited to 300 units world wide, OcUK have secured all of the UK stock, which is due to arrive next week. Full aluminium and extreme high quality screams premium and unique.
Grab yours while you can.
Thermaltake Level 10 Limited Edition Aluminium Case - Silver @ £899.99 inc VAT
The “Level 10” concept allows gamers to experience the power of their high-end computers through the design itself. In order to achieve this, iconic design is combined with optimum functionality and innovative details. By rendering the inside components visible, the design concept focuses on the architectural aesthetics which are inherent in the computers and result from each individually configurable component. The inspiration for this approach the design team took right from the computer worlds themselves – expressiveness, virtual townscapes and futuristic game components served as orientation for the arrangement and the look of individual components.
- Model: VL300A2N1N
- Case Type: Full Tower
- Dimension (H x W x D): 666 x 318 x 614 mm (26.2 x 12.5 x 24.2 inch)
- Net Weight: 21.37 kg / 47.11 lb
- Colour: Black & Silver
- Material Aluminum Extrusion
- Cooling System Front (intake): 140 x 140 x 25 mm Red LED fan x 1 (1000rpm, 16dBA)
- Rear (exhaust): 120 x 120 x 25 mm Red LED fan x 1 (1000rpm, 16dBA)
- HDD (intake): Dual 60 x 60 x 15 mm Silent fan (2500rpm, 19dBA)
- Drive Bays: Accessible 3 x 5.25’’ / HDD Easy swap 6 x 3.5’’ or 2.5’’
- Expansion Slots: 8
- Motherboards: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 4, eSATA x 1, HD Audio x 1
- PSU: Standard PS2 PSU
- LCS Upgradable: Supports 1/2" 3/8" 1/4" water tube
- Other: CPU cooler height limitation: 150mm
- VGA length limitation: 310mm
- PSU length limitation: 210mm
Only £899.99 inc VAT.
ORDER NOW
Always amuses me why they don't picture the other side of the case... are they ashamed of it or something?
In the right house, I think that would look pretty cool.
That's quite possibly the ugliest monstrosity I've seen for some time. The handle, if indeed it is a handle is lol worthy and the ridiculously small gap between the drive bay and MB "box" compared the PSU box is horrific. The ladder drive cases would look nice if they hadn't decided to round them off so they look totally out of character. Innovative design it most certainly isn't (in my opinion of course).
