I've recently built a new machine, these are the specs:
Intel core i7 3.4ghz 3770k
16GB DDR3 1600mhz RAM (2x8GB)
Nvidia Geforce GTX 670 2GB EVGA
Gigabyte Z77X-D3H
800W PSU
Windows 7 Ultimate 64-bit SP1
The issue seems to be generally broad, random lock ups and blue screens. I've taken the following steps so far:
1) Checked that all components are inserted and installed properly, including drivers, also checking drivers are up to date.
2) Ran an overnight memory test on my RAM, no errors. I also switched the sticks into the previously unused RAM banks, this created no change.
3) Removed previously installed hardware with no apparent change.
4) Saved minidump files from the stop errors, the errors seem to be different each time, however when I open the files with the diagnostic program 'BluescreenView' I don't get a consistent cause.
5) I have tried running Linux Mint 13 and I also experience lock ups, leading me to believe that the problem is at the hardware level.
The lock ups and blue screens seem characteristic of a RAM error or other hardware issue, and so I do not suspect an issue with the PSU, however as the RAM check came up clean, this leads me to believe that the issue is with either the GPU or the motherboard. The GPU seems to perform as expected in every day use, and so I am more inclined to suspect the motherboard as the culprit.
Any input would be very much appreciated, if any extra information is needed, please ask.
Thanks!
Gigabyte Z77X-D3H
800W PSU
Thanks!
