Hi guys,
Having a few problems.
The only 2 games I play BF2 and counter-strike source keep locking up all the time. I did a prime95 run for 24 hours (bear in mind at stock settings) and it passed without a problem so the instability obviously doesn't lie with the memory or CPU.
I'm currently running a Sapphire X1800 XT (not overclocked)
I've checked the power rails and under load they all seem to be fine, the only thing that goes slightly lower is the 12v rail which goes down to 11.78v and the 3.3v which goes to 3.28v.
I've tried 2 PSU's, one is an unheard of make (yeah I know
) the other one is an ultra-x ATX 2.0 500watt psu. I did have a hiper 580 non modular for a a very short while but it crapped out after a day (kept cutting out) so I never had the chance to test if it cured the problem.
Reckon it's a PSU problem? I don't wanna have to fork out for a very expensive power supply only to find it didn't fix the problem.
) the other one is an ultra-x ATX 2.0 500watt psu. I did have a hiper 580 non modular for a a very short while but it crapped out after a day (kept cutting out) so I never had the chance to test if it cured the problem.Reckon it's a PSU problem? I don't wanna have to fork out for a very expensive power supply only to find it didn't fix the problem.
