Lockdown TT build
11 Jun 2013
I’m thinking of filling my weeks inside with an n+1 project. Never ridden a TT bike but why not?!
I think it can be done cheaply with second hand parts if you’re not too fussy about latest and greatest tech. Anyone got any tips or suggestions? I’m thinking 10 speed 105 from a few years ago would be fine. Would my measly 250w manage to turn a 53/39?
Shifters and wheel dictate the speed.
10 speed parts can be as expensive or more expensive than 11 speed parts.
53-39 will be fine, just ride up the block a little for a gear that works.
Gives you the chance to get ontop of it when you have a tailwind too.
As Jonny said, you're probably better served with 11sp, if you need any parts go to time trialling forums, good active for sale section.
I have found that most of the *magic stuff* associated with TT frames is down to marginal gains...
For me, the key things were seat, frame size (I found a smaller frame more comfortable) and aero bar position: posh wheels are great, but my legs need to be better.
As you'll be using bar end shifters (presumably) the drive train will be driven by cost: I have found on my routes I *might* use four gears (normally three) and so what my legs are pushing is slightly academic.
If you're going new, go for cheap and sink the money into your position. ;)
CAVEAT: I am a very long way from even being below average, so bear that in mind!
I found last year an 11-23 cassette to be a “marginal” gain, I could keep my legs in my optimum cadence, eliminate that missing 16/18T I think on the 11-28T cassette which could result in quite a jump in the middle of the block.
I think mine was a cheap(er) Ultegra 6800 as they were being discontinued.
Looks like going Shimano anyway, but the Sram TT shifters are very expensive, even the not return to centre ones.
That kind of wattage and gearing will be great, you’ll be in the middle of the block which is best from a drivetrain efficiency point of view and small increments in gearing.
Towards the smaller gearing on the cassette at higher power/speed you’d be looking at larger chainrings and other stuff which will cost more money.
Thanks all for the comments!
Because they are getting rarer? I run 10 speed 105 on my (clearly quite old) road bike and was thinking of doing the same for the TT as it’s been very reliable and I can buy second hand parts to reduce cost and reuse wheels to start with etc. I need to do a mapping of what can be second hand and what I want to be new - crankset new but shifters and brakes can be second hand for example. I’ve found a 105 53/39 crankset for £52 which seems like a bargain
I also want to try making my own disc wheel cover for £30 like GTN did!
Just how it seems to work, they sell less of them so can make more money per item vs selling loads of 11 speed parts for less margin.
If you go 11 speed at the rear you can run a 10 speed chainset fine and if you stick a 10 speed wheel in you only really need to screw the low
limit screw in a bit. Maybe a slight adjustment of the barrel adjuster.
Looks like the bar end shifters are about the same price second hand, certainly not enough to make it worth it.
https://www.chainreactioncycles.com...hVhF4SyrAiy1InsCE4EgY_5V2snrhpCxoCoLYQAvD_BwE
10/11 speed rear dérailleurs are basically the same price so one of these.
Don't know if you need a braze on or band on front derailleur.
Go single front chainring for the next marginal gain.
Just so I understand, I can run a 10 speed crankset but would need an 11 speed front mech and shifter because the 11 speed chain would need the larger front mech movement?
10 speed crankset and rings yes no problem.
Shifter and FD you might be fine with using 10 speed as it’s just a friction shifter rather than an indexed shifter.
The 11 speed cage might be a slightly different design, with 10 speed you can sometimes need to trim at the limit, ie big/big.
If you have them lying around then I’d try it, if buying new Id just buy the 11 speed.
An update for those who care. Got myself a second hand but barely used 2015 Ribble TT frame with a new 10spd crankset and 11spd rear mech. Just need the other bits now! I’ve worked out that I won’t need brakes for a few months so can buy those later
Nice!
Next major decision is to push the boat out a bit with really nice bars or keep it cheap and cheerful. I need the frame to arrive and see how it fits first I guess. 3T Aduro are going cheap but don’t think it will match very well!
