- 15 Oct 2011
- Bristol
I watched a Mythbusters episode yesterday, and the main topic was the hardest aircraft to fly. It was all about the U-2 aircraft really, and before watching that I had (shamefully) never knew it existed.
What an incredible episode, but more so incredible aircraft!
An ultra-high altitude reconnaissance plane that operates at 70 000ft, over twice the hight of commercial airliners.
https://en.wikipedia.org/wiki/Lockheed_U-2
The pilots have to wear pressurised suits, pretty much space suits, and have to go through an massive amount of training before being able to even just sit in the thing.
The fuel is kept in the wings, making them super heavy, so heavy in fact that they can't even support their own load, and need castor wheels attached to the wings that detach on take-off. And the planes wheel configuration is like none other, with just a set below the cockpit and a set to the rear just below the engine in a bicycle configuration, so is notoriously difficult to land.
When landing the pilot has little visibility on seeing the runway, so there has to be a chase vehicle driven by a trained U-2 pilot who will guide him on his landing.
The pilots usually spend about 12 hours at 70 000ft gathering intelligence, which is amazing for both pilot and aircraft when you think of it.
Anyway, enough of that. I'm sure all you aircraft fans know what it's all about
In the episode though, Adam, that geek with glasses actually gets to fly in the plane (after lots and lots of training, which is awesome to see) and they fly up to 70 000ft, you can see the blackness of space so easily as it's almost the top of earth's atmosphere really
lucky *******.
The best bit is the take-off though, the plane takes off after a very short time of accelerating, and rises at an incredibly steep rate in a circular motion.
Basically that episode just wowed me and introduced me to a spectacular machine. And induced horrible jealousy
I know the SR-71 went higher, and faster, but not for sustained times like the U-2.
Just watch the episode if you can, I won't link the YouTube vid as it's sort of copyright infringement, but I can't stop you searching
And yes there's not much point to this thread, just only hoping to introduce people to the U-2 like I was
EDIT: Sorry Surveyor, I thought Imgur had done it. Fixed now (1080p width too much?) Hopefully fixed now,
Really sorry
Third time's a charm
