Locking wheel nut help
27 Feb 2006
Normanton
My locking wheel nut key just disintegrated when trying to get my lock nuts off!! does anyone know what I can do to get them off??
There standard vauxhal ones but I dont have the 3 digit code you need to order I new one from vauxhal
Heres are some picks if anyone has the same looking nuts let me know as it might be the same code key I need.
Yep got the box with normal ones in, havent got the card with the security code on it, I will ring them in the morn just wondered if anyone had the same ones
Same thing happened with my s-class locking key. I just took the car to MB who had a set of all the keys, they tried one after the other until one worked and they removed all 4 nuts for me and replaced them with a new re-designed set.
