Basically I bust my locking wheel nut key when I put some different wheels on my car a few months ago... and tonight one of my back tyres was pretty flat, nursed it to the garage, it was on 6psi (usually pump to 32psi - 195/45/15's)
Luckily I'd tightened up (quite well lol) all nuts when I fitted said new wheels, but on the last locking wheel nut the key just snapped! Literally had just fitted new wheels typically and wanted to double check they're tight. It's a 3 pin key.
So basically I know I need to get this sorted asap now...
The locking wheel nuts I think are original vauxhall ones and were on the car (bog standard) when I got it, theres a pic below. I'm wondering can I get a key like this? Or if it's unique?
Or what are my options if not and this key is somehow unique? I really hope it's an off the shelf key though... but would a garage be able to sort this for me, cheaply, without damaging my wheels in the process?
and the mangled nut:
Thanks for any advice
