Loft boarding and carpet
20 Mar 2015
I want to board our loft and use it as a play room (not a bedroom) basically store some of my daughters bigger playsets up there such as her lego town and Barbie houses.
As I'm not in a position to convert the loft into an actual room, so would there be any probs putting carpet down on the boards?
Cheers
Problems such as...? Bit confused.
You can put carpet in your garage if you like or on the ceiling!
Carpet the walls - everyone loves furry walls!
Unless its not going to be flat I am not seeing the issue keeping in mind the weight restriction of not having a proper floor.
