Loft Conversion Costs?
10 Mar 2003
Hi,
Just wondered what the rough costs were?
I don't want anything stupid (like en-suite as I've found when googling) the property is a two-bed terraced house. All we want is a floor which may be used as a make-shift bedroom or storage.
Thanks,
M.
Just finished my loft, it has stairs up, carpet down, insulation, a radiotor and all the other things you would expect in a normal room. The most expensive part was the 2 Velux windows which cost around £900 fitted. Overall it has cost around £3000 to get another room out of this house which isnt too bad in my eyes.
Here are the final pictures:
I will get some more shots of the actual room if you wanted.
Hope this helps, Sam
It does have a staircase but as for being classed as another room when the house is sold I am not sure but I dont see why not :confused:
Something to do with building regulations I think, you'll not be able to advertise it as having an extra room unless it conforms to some strict criteria and has been assessed by a buildings inspector and signed off.
Stairs are one of these requirements.
Something to do with building regulations I think, you'll not be able to advertise it as having an extra room unless it conforms to some strict criteria.
Indeed, they made it far more ridiculous last year (I think) - probably something to do with "Saving the planet" :rolleyes:
Ok then but even if we did ever come to sell the house, we could maybe not advertise it as having 4 bedrooms (3 bed semi) but explain in the description that it is priced slightly higher than the average because of the loft and people would see when they came to view what it meant.
Not that we are planning on selling this house anytime soon, I love the loft :p
I love the look of the loft. I think £3,000 for something looks that good (and will probably get you around £8K minimum back on the price) is well worth doing.
Time to get saving I guess!
Thanks!
M.
Hyper,
Under UK law unless your conversion has the proper certificates and a fixed permenant stair case it can't be classed as 4 bed room and surveyor who came round would only price it as a 3 bedroom.
KaHn
Well I dont have any certificates for it but it does have a fixed permanent stair case. Anyway as already mentioned, I dont plan on moving anytime in the future :)
The basics are
In the UK, if you have 3 floors, the doors will have to have self closers and fire proof to 30 mins. Existing doors can stay but the 3rd floor new door will have to be a 30mins fire door and self closing.
The height of the conservation window or dorma window has a maximum sill height, this is so you can climb out there to be rescue by the fireman on a ladder if there is a fire.
There has to be a staircase designed to building reg - ie, min width, angles, size of the depth and height of each steps, width of each balustrades.
As to cost, it depends on the existing roof design it comes down to.
Type of roof - what frame is it, if its a V frame then you can pretty much kiss it good bye as you'll have to rip the whole roof down before you can make it habitable. If its a A frame then you have a chance.
If its a A frame then you need to check joist sizes and amount of load it can take and how much reinforcements joist you'll need.
Then you'll need to think about insulation (required U-value) and a window, both of which will apply to building reg and planning, respectively. Without a window it will not be considered habitable and to get a window in you'll need planning. Without building reg it'll not be habitable either and failure to get that will means when you comes to sell it, you won't be able to produce the certificate so the options will be.
1 - Apply retrospectively, risky as building reg officers checks on the build on different stages to check it comes to the requirement standards. And if you fail, you'll have to put it back the way it was, at your own cost.
2 - Sell it as a store room, but you won't get as much for your property since it will be 1 bedroom less. Not to mention the lack of the building reg certificate will put most buyers off.
So, get planning (mostly for the window) and building reg.
My dad converted the loft, doesnt count as a proper bedroom as it doesnt have fixed staircasin just a retractable loft ladder. It was used as a bedroom for my brother but now hes moved out we're thinking of getting a multi gym in there!
As has been said really, Its fine to convert your loft for storage space, but if you have converted it for a bedroom without Building Regs, then you cant advertise or value it on the extra room.
Building regs require more than stairs, you need fire proof materials and fire doors at the bottom or top of the stairs as well as a host of other extremely expensive items
We (my mum and dad) a loft conversion at home. Its only a decorated room with pull down stairs and proper flooring and velux window though. Its damned freezing up there.
Theres another loft (the main part of the house, not the extension where the other one is) that is huge. I reckon to properly do that loft out would cost somewhere in the region of £15,000 - £20,000. Theres also a water heater/storage tank in the middle of it that would need boxing in somehow.
Also remember to check your house insurance after you convert, if the room doesn't have full regs signed off it may invalidate the rest of your insurance.
a full loft job on a standard 3 bed house would be c25K if you need to include a dormer/extension to the roof.
Building reg's are a right bugger, so if you're doing a home convert, then you need to do your research. Plus new wiring will require Part P sign-off as another paper generating and money consuming exercise.
enjoy the land of paper and p*** poor bureaucracy!
