Good Morning all,
Just trying to gain a bit of information from people who have added loft conversions on their homes.
We have a 2 bedroom bungalow which has a monstrous loft space which is in need of converting in to a third bedroom and en-suite. I’m at a loss of where to start really hence the thread. I think my main point of contact would be to fill a council householder enquiry form and see wether planning would be needed for anything and for the building regs needed for a loft conversion…
My one main question for you all is what do I need to do to get started? How do I find out the required information regarding floor steels? Etc. Do I need a structural engineer and express to them what our intentions are as well as the council householder enquiry form?
Thanks for your time, any information would be great.
). As far as figuring out how to go to, you can basically either find yourself an architect first, or a builder first. Most builders will likely have an architect that they work with. We did plenty of research on local builders, and ended up with 4 different quotes which varied a lot (they will, especially in the current economic climate!). In the end we didn't go with the cheapest, nor the most expensive. It was really down to gut feeling and fingers crossed so far it's worked out well. I'd ask around locally, take comments on local FB groups with a pinch of salt (local tradesmen will always recommend themselves etc.!) and find out who is part of the FMB and other such groups. We actually found most of our builders from seeing their signs outside some of the bigger/nicer houses on the local area that were having work done
