Want to get a loft ladder to replace the 630x650mm hole I have now.
Rafters are 630mm apart so looks like I’m limited to 600wide by 1200.
House is 1902 build with 220mm of loft insulation but not sure it’s worth going for a massively efficient hatch integrated.
Any decent ones to recommend? Fakro look good but also seen some cheaper alternatives. Some good reviews, some not so.
Thanks a lot !
Thanks a lot !
