- 19 Oct 2008
Hi,
As per the subject, has anyone used the Soundstation3 speakers with the PS3 and had sound through only the right speaker only?
I have the left cable plugged in correctly but I`m not getting any sound through the left speaker. However, if I remove the left speaker cable from the back of the right speaker I do get some feedback through the left speaker as I remove it or reinsert it.
Darren
PS I`ve just noticed that an update is availble for the PS3 so am installing that to see if it makes a difference.
UPDATE:SORTED. THANKS. SIMPLY THE LEFT CABLE NEEDED TO BE PUSHED IN HARDER
Darren
