Could you post a photo/set of photos showing the connectors clearly? I can tell you want it is then and you "may" be able to use a generic cable in it's place. Otherwise the options are making one yourself (involves soldering) or finding someone to do that for you (I don't think logitech will do it, might be worth asking).
It is not standard and logitech say damage is caused using standard serial cable.Vga extension no good either.logitech may have something now but they didn't have when i phoned 4 month ago.
