Logitech Air
8 Dec 2004
Hampshire
So Im sometimes watching iPlayer or a movie on my LCDTV through my PC and I dont have any direct control over my PC unless I go over to my desk and control it from the keyboard/mouse connected to that PC...
Could I use a logitech air to move the mouse around the screen so that I can control the playback etc?
Also could is it possible to use two mice type devices at the same time? I.e. my wired mouse connected to my PC and the "wireless" Logitech Air?
And finally, how good are these things? Are they accurate?
Would pressume so, I use 2 mice on my current gaming pc as each has its uses in different types of games, just leave both plugged in and both work one is a razer the other logitech so mixed brands are fine aswell.
Ah good. Dont suppose you used this logitech air sypher?
Unfortunatelly not, but I do have a media pc in the lounge which I generally just use for playing films etc from and just run that off a standard logitech wireless notebook mouse (but I generally dont need a keyboard for that) which work fine, I presume if your gonna use it for iplayer and youtube etc you want the ability to type aswell.
If you want a cheap alternative for just basic htpc needs. There are loads of wireless controll apps for smart phones, like Jumi.
Gyration do a media centre remote with mouse control, it works like a wii remote.
Thanks k3v.
AH2, is there anyway to get the screen on the iPhone to display my main LCD TV? (im currently running two monitors)
Thanks k3v.
Sorry no idea, I use duplicate display settings.
Pro version has many more options, so maybe worth looking into.
There's also loads of similar apps, so one of the others may do it.
