- 10 Jan 2006
Hi, okay, I've just installed Windows XP SP2 on my new PC, and everything has installed fine with the exception of my mouse/keyboard drivers.
They both "work" but when I installed the software that came with the PS/2 Logitech Cordless Desktop MX mouse/keyboard, iTouch version 2.15, everything got a bit crazy...
At first, I got the Secure Connect window appear, telling me there had been a problem, and I should press ctrl, left alt & F12. Nothing. So I had to close it. It appeared again and nothing again. Okay... so I closed it, and checked for the latest drivers.
There are newer drivers, version 2.22, on the Logitech website but when I downloaded the Win XP version and tried to run the it222enu.exe file, I'm told "Sorry, this software is not compatible with your operating system. Your device will still provide basic functionality. The Installer will now close."
Great. Well, I installed the latest mouse drivers and there was no problem... I tried uninstalling the old iTouch and installing the new version, and still no luck. I went back to the version 2.15 on the CD, and the mouse stopped working! So I took the mouse driver off and put the old one on, but to no avail... So I tried the new version again, and the mouse works again. Very odd.
Currently the control pannel tells me I have an "Easy Internet Keyboard (106 Key Ctrl+Caps)" which I have no idea if it's correct, and an "MX700 Cordless Optical Mouse on the PS/2 Port" (correctly). The keyboard is now running Driver Version 2.15 (using i8042prt.sys, itchfltr.sys and kbdclass.sys, if that means anything to anybody); The mouse is running Control Center version 9.79.025 and Mouse Driver version 9.79.
I can't get the F-Lock key to work on the keyboard, possible others but I dare not try them! Nor can I get the keyboard into secure mode, with the application not recognising my ctrl, left-alt & F12 key combo to get onto the next step.
If anybody has any ideas how I'm meant to get the latest drivers on, get all my function keys working, and get this keyboard into secure mode, please let me know! This is driving me crazy! It's 3:17am and I have work in the morning; I've been trying to get the damn drivers to install for about 5 hours now
), but once or twice per boot, I will get a full-screen secure connect problem. It says the keyboard is not in secure mode on the iTouch software. Any ideas on this one people?
