Logitech Cordless Internet Pro
11 Apr 2003
Notts
Hi all, got this keyboard, and worked fine, but just done a format, and installed the new iTouch software, and it is only alllowing me to use 3 of the function buttons on it, I cant manage volume, etc now and I could before. I also see no way of adding these buttons to the iTouch program, and it does not display them... Help!
jcb33 said:
USB and as I said iTouch software is installed, and this is what they give you when you download the drivers :/
If you've got Vista installed then there's no solution - unless your Logitech device is supported in setpoint there is no vista compatible drivers. I'm in the same situation with my keyboard/mouse.
waso_dude said:
in vista??
i've been having logitec driver problems with my G7 mouse.
Sorry, im using XP MCE, and its seems to be the media buttons that wontwork
Media, Play/Pause, Mute, Volume + and Volume -
