logitech dinovo edge
ryu
ryu
25 Oct 2002
so is this keyboard as good as it looks? :cool:
ive got a 50% off voucher from logitech and im thinking about getting the dinovo edge for £65 (half price), my dinovo is on its way out and the edge looks like the logical step forward.
few questions
1. can you use it in the bios with the dongle that comes with it? i use to beable to use the dinovo in the bios with the proper hub(but i sold the mouse/hub and am now using a generic dongle that doesnt work in bios)
2. ive seen a few videos of it, and was wondering can you mute that noise it makes when you change the volume?
3. are the keys still next to impossible to remove to make it easier to clean?
4. recommend getting it over the the wireless illuminated or the solar kb?
only thing that annoys me is that charging cradle, read a few comments that it can cause scratching to the silver wrist rest, which seems like either questionable design or a way to encourage people to buy again when it becomes grotty. would be better if there was just a usb connection to charge when required.
thanks
it works fine in bios using the dongle
Mine doesn't make any noise when changing the volume (I didn't know it could)
Haven't changed the keys but it does get dirty very easily and seems to attract dust
I have never tried any of these but its certainly a good keyboard especially if you do lots of typing.
Hope that helps
