** LOGITECH DRIVING FORCE G29 RACING WHEEL FOR PC - FREE DX RACER SIMULATOR STAND WORTH £84.95 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
This racing wheel is the current flagship product from Logitech and incorporates multi platform support, award winning realistic pedals and a dual motor belt driven base. Featuring 900 degree rotation and realistic paddle shifters it really adds to your sim racing experience.
They will not be going this low again so be quick to secure yours.
This is a perfect opportunity to upgrade your setup or enter the thrilling world of sim racing, Perfect for titles like Project Cars, Driveclub, Assetto Corsa and many more!
Logitech G29 Driving Force Racing Wheel for PS3, PS4 and PC (941-000113) @ £299.99 inc VAT
The Logitech Driving Force G29 Racing Wheel gives you the definitive racing sim experience for the PlayStation 3, 4 and PC.
With a powerful dual-motor force-feedback mechanism and helical gearing, the G29 provides smooth, accurate simulation of traction loss, weight shift and drifting to help you feel every turn in the road.
Respond with precision - the Driving Force Steering Wheel is engineered with solid steel ball bearings in the wheel shaft and stainless steel paddle shifter and pedals that gives you accurate control as you tear up the track.
Expertly modelled after automotive transmissions gears, the G29's helical gearing delivers smooth, quiet steering action. Anti-backlash keeps the wheel and pedals tight to maximise control and reduce unwanted noise and vibration for ultra responsive game play.
Race like never before with the G29's 900-degree lock-to-lock rotation, which lets you turn the wheel two and a half times.
Specification:
- Compatible platforms: PS4, PS3, PC
- Connectivity: USB
- Colour: Black
- Controls: 10 buttons
- 3 pedals
- Vibration Feature
- Other features: Anti-backlash heical gearing
- Easy access game controls
- Responsive pedal unit
- 2 year manufacturer guarantee
- Dimensions: 322 x 300 x 437 mm (H x W x D)
£299.99 Inc. VAT
ORDER NOW
COMES FREE WITH
DXRacer PS/1000L/N Racing Simulator Table - Black @ £84.95 inc VAT
Only £84.95 inc VAT.
ORDER NOW
VIEW THE FULL STEERING WHEEL RANGE AT OVERCLOCKERS UK
Great wheel, bought one to replace my very old g25 (which was still working well btw). Love the brake force mod they added to this. And having the the buttons on the wheel are a big help over the g25.
Shifter is a separate purchase. It`s more compact and a lot tighter than my old g25 ever was.
I personally wouldn't upgrade from my G27 to this Uber.
If it were my first wheel then most likely yes as it has a good number of buttons on it which I use a lot.
the extra shifter could be had for £25 if still about. for those considering this for games like dirt rally i would definitely get that as you use it as a handbrake.
Anyone know if they've sorted the drivers on these yet? I have the G920, basically the same wheel, but I've put it on ice for a while because it was too annoying getting it to work properly. (GRID: Autosport for instance doesn't like it at all. It seems to be an issue with it not really being recognised as a game controller by Windows 10.)
They will surely do so eventually, so worth buying anyway while it's cheap!
No still the same, I had one before Xmas, the G920, same drivers, mine went back as the list of games it doesn't work with still is larger than those it does successfully, went with a TM 300 GTE flawless all around.
What games did you have probs with ? Played American truck sim, assetto corsa, project cars , dirt rally. All work fine. Running latest driver on win 10. Even had it working on gta 5 with the x360 ce mod.
Only issue I had with mine was the down shift either not working or double clicking. Got a replacement and all good! It's like the g27 and dfgt had a baby.
whats better this wheel and pedals set or the t300? i would love to buy the t500 but cant justify the money for all that i would use it
technically the T300
if you can wait then we should have the T300 integral soon which is in my opinion the best solution on the market for sub £400 right now.
except its not available yet. so its not on the market... you know what I mean :D
That set looks good any idea on the price?
