Logitech Driving Force GT Steering Wheel
27 Apr 2007
Hi All
I wanted to get one of these wheels for use with F1 2010 but the problem is I have a metal bar under my desk which is the frame.
Could someone please tell me how the wheel fits onto a desk and if there are any adjustments to the fixing.
Thanks
Alan
It clamps on. You can adjust the clams with provided spacers so that you can use it on thinner desks, but if your metal bar is large or not flat, you won't be able to mount it easily. Look on the internet for reviews of the DFGT, they will show the mounting system.
Thanks for the reply.
The metal bar hangs down 32mm and is 18mm wide.
I have looked on YouTube but I can't find any info on fixing.
Alan
Someone on the LFS forums measured their G25, I think the clamps are the same on all Logitech wheels...
