Logitech Driving Force GT
23 Jun 2004
Blackburn
Looking at getting a new wheel. Dont want anything overly fancy like the G25 or 27, cant justify that much money. Have been looking at the Driving Force GT, i know its a PS3 wheel and supposedly works on pc, but how well does it work on pc. Are all features supported when the wheel is used on pc? force feedback etc.
Thanks
everything works fine with the wheel. I got mine for the ps3 but it works just as well for the pc. You will need to install the logictech profiler which i think come with the wheel if not you can download off there website this let's you map all the button and lets yo adjust for 0 to 900 degrees.
Hope that helps.
It works perfectly on the PC, Logitech supply a full driver set on their website. Great wheel for the money and easily the best in the less than £100 range.
