I'm sure this is a long shot, but, I have a logitech illuminated keyboard, and to use the function buttons you have to hold down the FN key. In set point you can make it so you dont have to, but instead you have to hold down the FN key to use the F buttons eg FN+ALT+F4.
So, is there anyway to make it so pressing the FN button toggels between the two, instead of holding it down? without having to go into setpoint each time?
Apoligies for having such a pathetic question.
