if the keys printed are your board are wrong, then you have been sent the wrong region's keyboard. If the keys are on the right place you would expect (@ above the ' key above the shift key for example) then i imagine all you need to do is switch the windows settings.
control panel > clock, region and language > change keyboards or other input methods > switch the default input language
