Logitech g11 problem...
27 Oct 2005
Netherlands
:( I've just got a logitech g11 gaming keyboard ( g15 without lcd...), Instaleld software etc.. works fine exept: Media keys dont work, i'm talking about:
Next,previous,volume slider, mute, play/pause, stop...
Those buttons dont work :(, i really need them one of the main reason i got this above the eclipse was for the top media buttons and the 18 G keys on the left...)
Any idea's?
g00dsh0t said:
start/control panel/Administrative tools/Services/HID Input Service
Long shot, but have you cheked its on automatic?
Its on auto, when i try to start in manually tho it says error2 : file not found
ChoÞÞer said:
as it may be your media player, next track and that didnt work with my itunes
Old multimediakeybo worked with windows media player & worked with volume....
EDII just read this:
he Play/FF/REW/NEXT TRACK/PREV TRACK buttons don't work in Winamp? Why?
You haven't enabled the "Global Hotkeys" feature in Winamp. In Winamp, go into PREFERENCES and put in a checkmark to enable the Global Hotkeys function. If that doesn't work, go into your DEVICE MANAGER (Right click on MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MANAGER), and scroll down til you find HID INPUT SERVICE, and
HID obviously isnt started, and i cant start it manusally because it gives error, anyone know how to fix this??
Fixed one prob with hid now a 2nd one arrived, says no device found for it, also devices dependant on the app list is empty...
CHUDS said:
should have got the g15 lol...its lovely ;)
I'm not spending 20 more euro's for a tiny extra lcd, while i can have a 17' crt for 20, and i have enough space to plant 2 more crt's if i wanted, but 2 monitors is enough for me atm...
50€ was already a lot for a keyboard, but 70+ is way too much...
I wanted the g11 above the saitek purely for the media keys and g-keys, otherwise it'd be saitek for me...
I think there should be some Sticky with this link in wich i posted earlier, as quite some g11&g15 owners have the problem ( any chance to put it in one of the sticky's?:)) : http://www.g15forums.com/forum/showthread.php?t=1932
The G-Keys also known as the Macro keys are mainly hated by the BF2 community, just because you play BF2, so even though I wouldn't use macros in games, a lot of BF2 servers will ban you for using them to create bunny hoping, dolphing diving, repeat scripts.
Tbh i didnt know there were any i don't use them in bf2 as i dunno for what, i'm using my mouse buttons for duck, lie down on floor, reload, etc... (all most used actions set to my 5 buttons on my mouse...)
I mainly use g keys for stuff like shutdown, sleep, wake, launching often used programs and in gta:SA for stuff like login and admin scrips (i'm admin on some servers...)
I'm only playing on 3 servers by the same makers, and they so far haven't banned me....
Wahts bunny hopping&dolphing diving and what scripts are there to use :confused: ?
