Make sure the plug in is enabled in wmp, cant remember the exact route to enable but i it is fairly easy to find.
~Slash
it works out of the box with Vista 32bit, but I know the 64bit vista had compatabilty issues a while back?
u running 64bit vista?
Nope 32 bit XP....
have you tried the drivers on logitechs website? they got updated a few months back?
Go to Start -> Run and type "services.msc"
in the list that comes up, make sure "HID input service" is running, and set to Automatic.
It is set as automatic, but when I tried to start it, it says "Error 2: the system cannot find the file specified.
thats your problem then, that service controls the media buttons on keyboard etc
