Quick one: is there any program for the G15 that will display the volume, maybe with a nice bar or something?
Thanks,
Craig.
Thanks,
Craig.
Thanks,
Craig.
My G15 Rev 1 has one, don't yours ?
Logitech Media Display is installed be default and displays when you change the volume.
it should be, its not tied to an OS...its tied to the g15 only. have you started the applet by double clicking on it, and did you put it in the right folder?
yea, it should still work, your just using a newer version of the logitech software same asmyself...In the LCD control panel, have you got it set to Immediate Display of High Priority Items, as that will need to be checked for the app to bring itself to the front when you change the volume.
