Logitech G15
i know core temp works with it, i dont use real temp but google g15 apps, im sure theirs various apps out there that do allow you to do so.
Is it possible to display cpu and gpu temps at the same time on the G15 lcd, i use msi afterburners osd for my sli gpu's temp monitoring, i know that afterburner is compatible with the G15 as is coretemp, but wondering if both can be displayed simultaneously.
Thanks for that mate, im currently using a saitek eclipse 2 on my main i7 rig, think ill swap it over for the G15 v1 on my other machine.
Late reply, but I used to use Everest to do the exact thing.
