Logitech G25 Power Adapter
n3x
n3x
2 Nov 2005
Surrey
My G25 died a few weeks ago and logitech have send a whole new replacement which is awesome!
But when trying the new AC adapter on the faulty wheel it suddenly works fine so it seems all i need is a new adapter, question is where would i find one and are they even available outside of logitech?
Has anyone out there been able to find one that works? :confused:
How did you go about getting a replacement did they just send you a new one when you rang up?
do by emailing them, explained that it wouldnt calibrate propely and they sent me a whole new one!
All it needs is a new AC adapter and it works fine, surely you must be able to buy a new one for it? all it needs is power so it would be a sin to just throw it away.
anyone? :confused:
What is the voltage and amps indicated on the unit? If you can find one with the same volts and at least the same amps, and the end fits, it should be fine.
thats what i was thinking but the connector that plugs into the wheel itself doesnt look standard to me. Just wondered if anyone out there has come across this before.
We lost our power adapter and found a laptop charger I think from a electrical parts store (3 letter name) that worked.
You said the connector doesn't looked standard? mines just a round connector with center pin which was a perfect fit, but we did have to mod the bottom of the wheel as the plug was right angled and the wire was abit thicker then the standard wire so wouldn't sit flush so we chopped a bit out of the bottom.
Power pack is 24V DC output @ 1.75A
To the people that have replaced theirs, did you unplug it from the mains every time you didn't use it? I leave mine plugged in all the time, and it's been fine for 2 years now.
yeah mine was left plugged in all the time.
