Logitech G27 with GT5
7 Jan 2003
Gold Coast, Australia
Just a few questions.
Firstly I have the G27 and GT5 but the steering wheel does not appear as a listed per configured setup under the GT5 options is there a reason or update for this? Also how do I setup the manual gearbox or flappy paddle? Further to this is the clutch supported in this game?
Thanks for your help.
Maybe this helps:
"HOW TO SHIFT WITH THE SHIFTER AND WITHOUT THE CLUTCH
When you first start the race, if you don't use the clutch, you won't need it.
The game will allow you to use the 'H' pattern shifter without the clutch.
However, once you use the clutch, the game will engage its usage and require you to use it to shift.
WHEN CLUTCH USAGE IS ENGAGED, YOU MUST USE IT TO SHIFT
Once clutch usage is engaged, if you don't use the clutch between shifts, you will get stuck in neutral.
Make sure you use the clutch before using the 'H' pattern shifter to select the next gear.
If your timing is off, you will get stuck in neutral."
