Logitech G500.. Couple of questions.
20 Jun 2012
Essex
Hey guys, just received my Logitech G500, couple of questions though.
The weights.. do you use them? I have tried a couple of combination but haven't got the right feel yet.
Also, the wire keeps ravelling back up on itself, getting little loops in the wire which is very annoying.. I assume this is because its new but is there anything I could do to get rid of it overnight? Maybe place some weight on it? Or will it just go away with time?
Thanks. :)
I use the weights, i have 3x4.5g and 3x 1.7g all spread around.
With regards to the wire, i just left it to sort itself out, cant remember how long it took but it wasnt more than a couple of weeks. I have in the past held the wire tightly with a cloth and smoothed down the cable from mouse to tip a few times and this has helped loads.
Hope this helps
