- 29 Oct 2009
Hello all
I know its early but i have woken convinced its my G500 after a long spell last night...
I have been having issues with the Minimise Maximize and Close buttons on all browsers and Windows Explorer. Also to add right click does not work in Explorer.
I have narrowed it down to the button in the middle of the G500 to make the scroll wheel click or not as you scroll. If i make it smooth all the problems go away? Is this a known issue with the G500?
Is it on its way out as its only 2 years old at most?
I thought it was an Aero Theme issue i have run all tests its not. It all goes away when i make the G500 smooth on the scroll wheel?
I have updated drivers tried older ones its still the same.
Thanks for your input.
