Logitech G502 button mapping
29 Oct 2002
per title, I've been trying to work out a way to make the DPi up/down and the scroll wheel left/right click buttons into selectable mouse buttons, but the Logi G software only allows you to select from keys/functions, has anyone managed to work out a way to make them say button 11, button 12 etc so that they can be used in applications such as WoW...?
Cheers
been trying this too
i haven't done it yet (not sure how) but you need to assign a keyboard button , say "J" to weapon 1 for example, then make that button in the Logitech software to "j"
LG hub software is a total pita, at some point they updated it and prevented use of modifier keys like shift and ctrl to be used as binds, there's 2 pieces of software you can use that allow you to remap any keys to your mouse
https://support.logi.com/hc/en-us/articles/360059641133?version=1.0.18
https://support.logi.com/hc/en-us/articles/360025298053
Hi, thanks for the reply, this is what I'm currently using, more or less, and it doesn't allow you to remove an assignment and treat is as a generic button, as was suggested earlier the only option that I can see is to bind it to spare keys in each game, but this would get messy and need different progfiles etc, hence just wanting to make them generic buttons.
yes!! I have to reinstall mine weekly re copy of the settings file :/
keeps losing my mouse n keyboard
Maybe you can set profiles for the mouse, so when you load each game you get different binds/macros activated as you load each game.
