- 14 Dec 2008
- UK
My mouse doesn't glide like it used to, can you replace the pads ok on bottom of mouse?
Yep, shouldn't be a problem.
Rather cheap (although not sure how much postage is) from Logitechs own website.
http://support.logitech.com/en_gb/product/g502-proteus-core-tunable-gaming-mouse/spare-parts
If you are going to replace the feet anyway. I would be tempted to try a small amount of polish and wiping the feet with a cloth (Pledge or similar)?
It worked for me!
