- 22 Apr 2008
Hi all,
I have:
Logitech G51 5.1 Surround Sound Speaker System
in this:
Creative Sound Blaster X-Fi Platinum Fatal1ty 7.1
My front left speaker makes a buzz noise like the speaker is popped.. but it is not. I installed the latest drivers for my 64 bit VISTA system for Creative sound card and it stopped the problem for a while.. But now it is back (i don't think the drivers have been touched since)
Is this something that someone else knows about. Should i return the speakers or is it sound card drivers?
If you don't know how to answer.. could you atleast point me to the drivers that work for you and the main application you use to regulate your card and speakers.
THANKS A BUNCH
I have:
in this:
THANKS A BUNCH
