Logitech G700 Wireless Gaming Mouse Discussion
15 Oct 2005
Hello, anybody else with this mouse?
I find it that the battery is dying VERY fast compared to my revolution mx under same settings (ie default) and same usage.
Anyone else?
is this mouse any good,was gonna get last week but changed my mind as i have the razor mamba,but i really like the look of this mouse...marks out of 10?
I like it, the battery probably lasts as long as my old MX1000 did which was 3-4 days of use.
The old MX1000 started to get very hard to charge properly, the slightest knock would stop it so this was the reason for getting the G700.
I've been using max gaming power setting and a report rate of 1000 since Thursday and it has just a few minutes ago gone critical.
I'm not sure how many hours this is but I'd expect between 11-14 hours if I roughly work it out.
I find the battery light indicators goes from 3 to 2 to 1 fast but it takes far more time to get to critical.
I don't find it an issue when it does run out of power as the USB cable doesn't bother me as much as I thought it would.
11-14 hours sounds about right. When I said a day I mean it will last a full day if needed. I charge mind up when it's not being used more out of habit.
Guys, i have contacted logitech support regarding the poor battery life and this was their reply:
As I understand the battery life on your G700 last around 2 days. The battery should last about 2 weeks. I would therefore advice you to go back to the shop where you purchased the G700 from in order to get a new one. The reason for this is that you have a 1 year warranty with the shop that you bought the product from in the UK.
Has anyone else experienced ~2 weeks of battery life with this mouse?
