Logitech G700
17 Mar 2011
Snowdonia
I really need a wireless mouse for general use and gaming, is this worth getting? How does it connect to the pc, there's no mention of a reciever and I dont have wifi/blutooth built into my mobo. The battery life doesn't seem that good either.
http://www.overclockers.co.uk/showproduct.php?prodid=KB-186-LG&tool=3
Also, is the G700 compatible with the Logitech reciever that comes with this kb+m set?
http://www.overclockers.co.uk/showproduct.php?prodid=KB-199-LG&groupid=702&catid=23&subcat=1278
Thanks
The G700 comes with its own little USB receiver and cannot be used with the standard unified receiver.
The battery gives me about 3-4 days of solid use, and you can use the mouse whilst charging too (comes with cable) :)
Thanks for the info. 3-4 days of charge doesn't sound too bad to me.
Can you attach the recievers to the usb ports at back of a pc without it interfering with the signal? Whats the keyboard like by the way?
