Logitech G920 Setup
15 Feb 2008
Hi,
I got a G920 today and having trouble setting it up, have updated to latest f/w + software installed but in games the steering will randomly lock the wheel to the right.
Also the brake pedal (middle) when pressed it only recognizes it pressed about 80% yet all other pedals are 100%. In Euro Truck Sim it is like the brake is fully pressed so the trcuk won't move unless switched to keybaord only.
I'm sure this is me been stupid but can't figure it out.
Have tested both Euro Truck Similater 2 & PC2.
Any help
cheers.
Not sure what is going on with the wheel but for the pedals you need to look for an invert axis option. At the moment it sounds like the brake is 100% until you press the pedal and inverting the axis should fix that. As for it not going to 100%, the brake pedal is a heck of a lot stiffer than the other 2 and you really need to stand on the thing to hit 100%.
You can make the pedal softer if you google "g920 brake pedal mod" but when you get used to it I find it useful to not lockup your wheels as much as PCars.
My G920 often doesn't survive a PC startup. I end up unplugging it after windows boots then plug it back in and launch the Logitech gaming software to get it to work properly. Make sure you calibrate it. iracing, Asseto Corsa, Eurotruck and American Truck simulators all work fine.
