- 25 Sep 2011
Morning All,
Picked one of these up at the weekend as a common computer world had it for £96 with the intention of making life easier.
So far experience has been good and all works very well. But I'm slightly disappointing in the software so far as it seems quite restrictive, or at least as I've found, I'm hoping you may be able to answer a few things I haven't figured out..
1) Setting hardware buttons for fixed commands.
2) The ability to not turn everything else off - sometimes
These are just things that are completley software based but actually really restrict the experience I'm getting from it
I hope someones going to pop up and just say - do this..
I also hope thats not contact logitech
I want my tv to turn off when I long press the Blue button. And I want my Xbox to turn off when I press the Green button. Simple enough. I've set this in the software and the commands work fine. But they only work when the remote is on that exact device. So for instance when I'm on the activity Play Xbox. The green button will work fine and turn the xbox off. But the blue button does nothing in turning the tv off. But if I'm on the Watch TV activity, then the blue button will turn the tv off but the green wont turn the xbox off!! Grr! I hope this is just something I've done wrong but it seems the buttons are only applied for the devices when your actually on them. If thats the case, thats rubbish!! - Any Ideas??
If I'm playing Fifa on the xbox, sometimes I like to switch the dvd\surround sound player to Radio. Now depending on the situation I may be done playing the xbox or maybe I want to continue. Either way when I switch to radio, it turns the tv off.
The only option I have is to say 'never turn the tv off when switching activities'. But actually sometimes I want it to switch the tv off when changing to this, or between other activities.
There needs to be another option which says 'Ask if you want to switch other devices off aswell'
Any ideas?
Any ideas?
