- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
WIRELESS
ILLUMINATED
LASER ETCHED KEYS
LOW PROFILE
SLEEK DESIGN
Need I continue? No! This keyboard has it all!
Logitech K800 Wireless Illuminated Keyboard (920-002382) @ £89.99 inc VAT
You can work or play anytime with laser-etched, backlit keys that are bright enough to let you type in the dark. The keyboard automatically adjusts the backlighting to suit the lighting conditions. Or you can adjust it the way you like it with the press of a button. Sensors detect your hands as they approach the keyboard to turn the backlight on and off. Your desk is about to get sleeker thanks to the thin profile, clear edge, and streamlined, wireless design. Every stroke you make is comfortable, fluid, and whisper-quiet with the PerfectStroke™ key system.
You simply plug in the universal micro-USB cable for three to six hours for up to 10 days of battery life. You can even type while it’s recharging.
- Laser-tched, backlit keys
- Adjustable backlighting
- Hand proximity detection
- Perfect Stroke key system
- Logitech Incurve keys
- Fast, easy recharging
- Sleek, streamlined design
- Logitch Unifying receiver
- Advanced 2.5GHZ wireless technology
- Keyboard can be upright stored on your desk to give more space
- Power on/off
- Easy wireless setup
- Full size layout
- 3-year limited hardware warranty
Only £89.99 inc VAT.
ORDER NOW
ILLUMINATED
LASER ETCHED KEYS
LOW PROFILE
SLEEK DESIGN
- Power on/off
- Full size layout
ORDER NOW
