Logitech Keyboard/Mouse on PS3
10 Dec 2004
Is anyone using either the Logitech diNovo keyboard & mouse or Logitech diNovo Edge with MX Revolution mouse on the PS3?
Would just like to know if either of these setups work.
Many thanks!
I was thinking along the same lines myself. The diNovo Edge does look a really nice keyboard which would blend in with the PS3 asthetics perfectly. It's also Bluetooth so it should be able to hook up.
Some pics here http://www.trustedreviews.com/peripherals/review/2007/01/26/Logitech-diNovo-Edge-Keyboard/p1
Quite expensive though so would be worth while getting some feedback to your question before buying. You may be better off asking on a US forum as there's only a handfull of us PS3 owners on OcUK and I doubt anyone has tried a Bluetooth keyboard yet!
From what I'm reading keyboards seem to be a bit hit & miss.
I'm relly hoping the DiNovo's work as I've recently got hold of z-5450 & I like things to match where possible.
At those prices I defintely won't be buying before getting more information than I currently have!
Found a couple of user reviews that state both the diNovo & diNovo edge work but you have to use the USB dongle. For some reason the PS3 doesn't pick them up as Bluetooth accessories just wireless keyboard & mouse.
Decision time do I want diNovo or diNovo Edge. Like the looks of the Edge but lack of keypad is a bit of a turn off. I hate form over function calls it's always so difficult.
why would you need the numpad? you're not planning on running a version of linux excel on your PS3 are you? The lack of numpad on my laptop only ever bothers me at work, so i bought a USB one, but at home Im more than happy to do without - would imagine it would be the same on PS3 also.
