Logitech MX Master died. What next?
19 Sep 2024
England
Has anyone else owned the Logitech MX Master? If so, what have you used since that you would recommend? I liked the size of the MX but did find it cumbersome for twitchy shooters. I ended up using it for strategy games and relying on a controller for shooters. I use a cabled vertical mouse for work but the cable ends up hitching on something or affecting how I manoeuvre as it compresses, so am reluctant to relinquish wireless unless I can find a solution.
Get another one, there are newer models.
Biggest gripe I have with them though is they haven't got swappable batteries but to be fair have excellent battery life. Ergonomics are almost identical.
There's the MX Master 3S which is more of the same. For twitchy shooters something like the Logitech G G502 X PLUS LIGHTSPEED Wireless is a good choice due to the extra buttons but you'd miss the side scroll wheel if you used that a lot on the MX Master.
I will keep an eye out for a deal on the MX Master 3S. I don't tend to utilise additional buttons on mice. I reckon I'd always be hitting the left click buttons on the G502 unintentionally.
I looked into some more reviews and I reckon the polling rate may be an issue, so am waiting on a deal for a Razer Basilisk V3 now. Or any mouse suitable for a palm grip.
