Logitech mx1000 Help
1 Jan 2004
Walsall (UK)
Hi guys
I have had a logitech mx1000 for 2/3yrs and for some reason it wont charge so i think i need to replace the battery but not sure if you can buy them so ive posted here and hope some1 might be able to help, ive took the battery out and its a LI-ION L-B2 rechargeable battery, so hope some1 can help me out. :)
Many Thx
It might of been under warranty before you cracked it open and even if it wasn't Logitech are normally pretty good.
I personally don't think you'll be able to easily source a replacement battery, just bin it (recycle the battery ofc) and buy a new one.
