Logitech peripheral issue
4 Apr 2022
London
Hi all,
So, I'm using the G915 TKl keyboard, Pro X wireless headset and the G903 wireless mouse and they all seem to be intermittently struggling... Mouse lag, keyboard lag and losing sound intermittently...
All fine and dandy until.. now get this.. I change to a Samsung Odessy G7 32" Gaming Smart Monitor...
I am unsure if Logitech G Hub (current version 2025.3.696161) updated and caused an issue (I did uninstall and reinstall the G Hub software), although I did reinstall the AMD Adrenalin Software, but that was the same version as before all this happened...
I have started using my Logitech MX Anywhere Bluetooth mouse that I usually use with my Macbook.
Any thoughts on resolving this... It's very irritating!!
Win 11 fully updated
While I'm fond of Logitech mice, their software leaves much to be desired and G-Hub is frankly horrendous.
Can you try downloading LatencyMon and monitoring things for a little just to confirm that is the problem? Try it with and without the application installed while doing a spot of gaming.
Also, does your monitor have any sort of USB hub/passthrough that you might be using? If so, try disconnecting that aspect and running the peripherals directly from your PC.
Hi,
No usb pass through or anything like that. I'm convinced now it's G Hub. I've disabled it and used different mouse (Ironically its a Logitech MX Anywhere Mouse) and my Samsung Buds and mouse operation and sound are fine.
Shame as the actual kit, headset, mouse and keyboard are great and have performed flawlessly for a long time since I have been using them so I think I might look around for alternatives
ive noticed my mouse is fine but as soon I plug anything in the usbs next to my dongle the mouse cursor lags big time. thats plugged into the front usb 3 of my case.
Did you completely uninstall and reinstall the G Hub software?
I went through a phase where once in a while I would have the problem you're having. I searched and maybe it's to do with windows defender interferring with the software then it bugs. Never really found a solution but it's not happened for a few months now.
Did you get this sorted?
I was getting terrible lag on my Logi keyboard. Missing and repeating letters, or just lagging behind what I typed.
I worked out it was interfearance with the USB ports. Moving my Wifi antenna reduced the lag, but making sure my keyboard and mouse were on a different connection (USB 2/3/C) than other wireless devices has so far solved the issue.
